I want to replace the harmonic balancer from a V belt type to a multi groove type , does anyone now if a multi groove power steering pump is a straight swap for a V belt type ?
Hi Billy
It is a straight swap but you also need to change a tensioner pulley.
Thanks Joe are the fittings on steering pump the same ?
They depend on which fitting model you have but you can swap them over if it is a different type.
