I have a: 1991 Stealth TT
It has the following issue:
CD Player is not playing. After inserting the CD, I get the “E” error. Are there any common known issues with the CD Player that cause this error?
First up, try a cleaning disc to clean laser.
I cleaned the laser but the problem is it’s not spinning after the disc is inserted. Maybe the motor is bad. Not sure where I would find a replacement motor for a 30yr old CD player.
I used to have the same issue with my 1991 Toyota MR2 SW20. I would get error if i used “new” cds or if i burnt to a 700mb disc.
Issue was resolved when i used the old style CDs from the early 90s which were 650mb. You can still buy them on ebay.
But if you are sure the motor is bad, then thats a whole other issue.
I think this motor is bad. Looks like a Mitsubishi part number that was probably obsoleted 30 years ago. If anyone knows where to get a suitable replacement, let me know.
Have you tried applying power directly to the motor? If it works you may have another electrical issue.
