Turn Signals Not Blinking
Hello,
I have a 3000gt SL and I am unfortunately not good at anything electrical or wiring related, so i’ve come to find answers from people who are more knowledgeable. To start, the turn signals do not blink when turning on either one, the relay box under the carpet clicks once for the initial turning on of the turn signal, but then nothing after that, and the lights stay solid. Additionally, i’ve found that my hazards button will not activate anything unless the key is in the on position, and even when it is, it makes both lights stay solid on, just like with the turn signal lever. Is there any fix to this, or should i try to get a new relay box? While searching online, i’ve run across those three-pronged flasher relays, but i’m not sure how to, or if it’s even possible to, wire that instead of the 14-pin relay that’s already in the car. (sorry if that’s not the correct term for it, as i stated, i’m not knowledgeable on electrical and wiring stuff)
Thanks, Dalton
The original relays are not expensive so there is no need need to start messing with your loom. This is the most likely cause of the problem and if you don’t want to pay a auto electrician, I would just try a swap out.
Alright, thanks Joe, i’ll try it out and report back what the outcome is.
