Hello all my name is: Gaz I have a 1992 GTO non turbo. It coughs and splutters, back fires, wont idle or go over 3000 RPM, appears to spit out fuel through the exhaust and is now not driveable. Diagnosis indicates Throttle Position Senser or Idle Position Switch. I have replaced both of these but still have the same problem and same diagnosis. Any ideas? Cheers Gaz. And now it wont even start.
Hi mate, i’ve been having a similar issue recently. Smaller sensors like those dont tend to be the issue a lot of the time.
Check your fuel delivery system mate. Fuel pump especially - run 12v through it when it’s out the car and see how it behaves. There’s a chance it might be going bad if you’ve let it sit for a while without fuel in the tank as they can internally corrode and seize.
