Hi, I have a mk1 gto t/t 1990 H reg with obd1, is this compatible? I’ve done a few alterations and dash is like a Christmas tree so need to delete lights, I’m in Uk, how much would cost be to supply and deliver?
Regards
Regards
Yes it’s compatible with your MK1 GTO T/T’s OBD1 engine computer. In fact, even if you replace your engine computer with an aftermarket computer, it can still communicate with remaining factory computers (ie. ABS, SRS, etc). The price is still $245 USD delivered to UK, and I have several in stock.
Hi, I hope you don’t mind me asking. I bought one from you a few years ago and only started using it recently. Do you know if there is any information to use along with scan tool - for example I used it to alter my TPS settings and it gives the live % on the screen. Is there any information to see what the correct % should be so I can match it on the scan tool. thanks
If the TPS value is under 10% it will trigger a CEL code for a faulty TPS sensor. Generally I see about 14% at idle. For adjusting the TPS, I suggest following the factory service manual recommendation. 3SG - Technical Reference Manuals
Perfect, can I order one
Sure you can order directly from me using paypal. If you use the ebay link, it’s higher cost because of ebay fees. Paypal using this link:
or send paypal to this email address: [email protected] (note the underscore).
Hi, payment sent. Thanks
Payment received, I just verified everything works correctly and now I will ship it out today.
Antero’s multi computer scanner for all 3000GT’s has saved me many times! Perfect for mut/hybrid OBDII and ODBI, highly recommend it!
Hi @BlackStealth! Just wondering if this scanner will also work if you have installed a Jester Chrome ECU?
Yes it does support the Jester Chrome ECU. It has a section in the configuration menu for “Chrome ECU? yes/no”.
Latest software update now supports 409 different Mitsubishi engine ECU types! I spent half a year decoding the Japanese rom cartridge, and the North American rom cartridge for the MUT2 unit !!
