Temperature control screen 1 of 2 probs
Nightmare ,just dropped TT off for respray and put battery back on the auto as it had gone flat about a week ago.
Started first time as always but the temperature control screen has no light or shows what the buttons are doing. Still seems to have blower and temp controls?
Is there a fuse or relay that could have blown when battery reconnected. or what would you suggest I should do next?
This is a common problem. It is coincidence that it happed now. The display can be cheaply repaired. There is a video that shows how to remove it without damage. I can repair it for you if you contact me by private message or you may be able to find someone else if you wish.
Thanks Joe as said the blueTT is in for respray so will sort it when I get that one back will ring you later
Hi joe maybe you know, on top of the ac unit there is a switch which goes to the left right or stays in the middle. Do you know for what it is?
