Long post: TLRD: Car is slow, don’t know what’s wrong ![]()
Hello everybody, having issues with my car…
I have a '95 Spyder N/A DOHC SL AUT FWD with roughly 60000km on the clock (geniun low mileage)
It is so slow, full power foot down takes around 16 to 17 seconds to 60mph (100kmph)
Car is a left hand drive, in Norway.
I am not in limp mode as i have all 3 gears plus overdrive. Foot hard down from stand still takes me to around 80kmph in roughly 10 seconds before it shifts to 2nd @ 6500 rpm. Seconds gears takes me to around 100kmph just before it shifts @ 6500 rpm for a total of around 16-17 seconds. In second gear it seems to ‘slow/bog’ for a split second around the 4000 rpm mark (this does NOT happen in 1st).
I have changed the HT leads / Spark plugs / PTU, and checked all the wiring to and from the ECU… it all looks and multi-meter pings correctly. Voltage values where applicable (according to workshop manual) seems to match of be within the specified values.
Car is a Cali version with 4 O2 sensors, but no matter what i do with these, plugged in, unplugged, before the cats, after the cats, without cats (using straight pipe) and any other possible combination seems to have no effect of the performance.
Fuel pressure has been checked and the original regulator replace with an adjustable one, currently at 2.8 bar, but tried plus 1 and minus 1 variations and all remains the same. Pressure holds at that value after the car has been off, at least for 3 to 4 minutes, maybe longer.
One thing to note, COLD - the car starts in an instant… WARM - it can take a few/several turns of the engine and a right foot to get it started…
Idle’s fine in all conditions… also in Neutral or Park it Revs up happliy
Now i know it is not a VR4 but it is about 2 times slower than what it should be (dont need to get into any arguments about this, I know it is old now and will have surely lost some power but non the less - its tpoo slow - something is wrong)
Now i got the car like this, after it was imported into Sweden and worked on to be the best 3000GT in the country, by adding a supercharger and making it fast as f@$K… the guy/garage who did this never got it working as they wanted it to be so they put it all back… i have no additional info on what they did or what they didn’t when putting it back to standard… all i know is that it has been slow since then and now im trying to find out where to start…
I bought the OBD1/MUT scanner tool from BlackStealth (3SX) and have no errors nor anything that looks our of the ordinary… but i also must admit that i have not checked deep into this as i have little knowledge about what to look for.
So, please (if you can) have a think and help me troubleshoot or eliminate things one by one so i can hopefully get my car running as it should. I don’t need no tire burning monster as it was not built to do that, but right now it is dangerous trying to pull out of junctions as i have no acceleration to do so…
Thanks in advance for any comments or help on this matter
Cheers
Ben
