Hello all, my name is Dan
I have a 1993 3000GT VR4
It has the following issue: The stock oil pressure gauge is at zero. It has done this before, and I figured out the connector at the sending unit was disconnected. Reconnecting it in the past had resolved the issue. But not this time.
I’ve replaced the sending unit, the pressure switch and the wiring harness itself (with all three connections). I’ve tested the new harness for connectivity issues, but signal doesn’t seem impaired.
The car drives just fine, aside from the cruise control also not working. The switch near the radio engages, but the steering column switcher doesn’t set the speed as it did before. Not sure if that is a helpful tip.
Could the new sending unit also be faulty? Maybe the gauge is dead? Or maybe I’ve missed a fuse somewhere?
Any help would be appreciated, thanks!
