Hi All,
I’ve been watching the videos on YouTube for awhile now but just came across the forum.
I have a 1991 NA 5spd GTO and surprise surprise it has some electrical issues. The previous owner had a lot of aftermarket electronics fitted, including interior and exterior neon lights, amps and subs etc. It was all removed before I brought it, the big issue is that he did all his own wiring.
I’ve had issues with the ignition since I brought it, but recently the SRS light came on and wouldn’t go off. My local mitsubishi garage suggested it was the clock spring. After some further research and playing around, I think I’ve tracked the fault to the ignition plug. I expertly gave it a wiggle this morning and drove the car for 30 minutes with no issues at all. The SRS light came on for its self check when the car was started, then went off and stayed off.
My big question is: since that plug has caused other issues, can it be the cause of the airbag warning light as well?
I have another clock spring but would rather not fit it if I don’t need to.
Any help would be greatly appreciated.
