Speedometer cluster
Hi any has a broken cluster from a gen1 turbo, i need the face of the speedometer in miles and km coz in my country we use km and my dial is in miles only, have big problem with speed cameras. :slight_smile:
There is a conversion kit available that adjusts your cluster to reflect kph instead of mph, its an electronic module and a KPH decal to cover the MPH.
Actually scratch that, itโ€™s probably only available Kph to Mph. All the Gto models should have Kph as the primary Dial
Enda
Hi
Assuming that your MPH speedo goes to 180 MPH then you can purchase a KPH dial that goes to 260 KPH and just change the face.
Here is a links to the seller : Type one : https://lockwoodinternational.co.uk/product/gto-kmh-dial-part-no-c620/ Type two : https://lockwoodinternational.co.uk/product/gto-kmh-dial-part-no-8093/
Hope this is of some help
Best Regards
Marc
I will try to change only the face with both miles and kilometers so that i leave the milage in miles since it has already a lot of miles in miles. :slight_smile: i am trying to contact lockwood for a custom made.
Thanks for your help.
Anton
Lockwood dont do custom any more. Its a pitty because they are really nice dials
If you just remove the face from your MPH speedo and fit a KPH speedo face the odometer and trip meter will still be in miles the speedo face changes nothing but what you see
Best Regards
Marc
Yes that was what i had in mind, but i wanted to be an oem not aftermarket. If someone has a broken cluster with both miles and kilometers i would gladly buy it. Btw i want it both miles and kilometers because transport malta may be difficult to see the milage in miles and the dial in kilometers only thats why i want both. :slight_smile: when the car is classic there are many restrictions.
I have one but I need in miles.
If you want we can exchange
Iโ€™m happy to pay postage and send it to you, if you are happy to do the same
Iโ€™m in UK, SL7 1TS. Where are you located?
BR
Stefan
Im located in malta :malta:. Mine is only in miles? Yours is in miles and kilometers or kilometers only? Any pics pls?
Hi
Check out this Ebay listing I assume this is what you require
Hope this helps
Best regards
Marc
Hi, i checked out every cluster on the whole ebay. The one you sent me the link is nice, but its a little expensive. Knowing that i only want the face.
Thanks for your help. :slight_smile: much appreciated.
Hi everyone, anyone knows if the clusters are compatible in all the years? Thanks
