Hi Folks, I need a pair of rear shock absorber/strut bushes for my 97 GTO. It appears they are the large tapered style fitted to the non turbo 4x4 imports. I recently purchased a pair of new struts from Rockauto that fit the hub but my springs and top mounts don’t fit as my springs and top mount are too small in diameter. I purchased new aftermarket units but they don’t fit as the bush is not tapered and too small. Can we we get the tapered bush for these cars? Thanks Kenny
I have the rear strut bushes for original struts but I can’t guarantee that they will fit aftermarket parts. I will get the measurements for you.
Many Thanks Joe, I measured the eyelet on the Rockauto shock and it appears to have the same dimensions as aftermarket one, hopefully the bushes you have will fit. Kenny
The eyelets off an R33 will fit
Hi Joe,
I am in need of the rear lower strut mount bushings that you might still have. I can’t send a pm probably because I am too new of a member. Is that correct?
I still have some. They are £29 each plus shipping. Should be around £10 to the states but I will check the price if you want them. Private message can be sent after 2 days I think.
