Does anyone have or know where to find the rubber line between the clutch master and slave cylinders? I believe the part number is MR151527.
Mine’s perished and I can’t seem to find one for sale.
Is this it?
Yeah, genuinely no idea how I overlooked that thanks so much
If you want to save some money. Ths is standard hose and fittings. You should be able to go to a local motor factor’s and they will make one for you while you wait.
buy a braided one .much better
Replace with a goodridge braided hose, measure the length and you want two female brake fittings on both ends (if you want to keep all the stock clutch damper system)
Might look into the other options then, amayama refunded me saying they aren’t in stock.
Out of interest does anyone know if it’s possible to just run a line straight to the slave cylinder?
