As you can see, the bubbling under the black sealant is pretty bad, I’ve ordered new clips and grommets, but was debating stripping, rust treating, and resealing this black section underneath the moulding.
oh were you talking about how to treat the area underneath that moulding? Im really not sure tbh, I know people just remove the moulding, paint it and be done with it. Is it just surface rust?
I have 1991 TT gto it had the same thing , i removed the strip cleaned up , rust treated paint then repainted and filled gap with marine greese to stop the water ever getting back in . got new moulding from Mitsubishi ( not cheap ) be its fixed now , hopefully for a long time
Iknow not great but one of those things , just a FYI Rockauto in USA is good for shocks if you need them as the GTO is also Dodge Stealth over there so lots of parts made in USA
this is correct, she made some adjustments to the bottom piece so it fits correctly. I think she is selling the bottom piece for around 120 US dollars.
cool stuff thanks for the help . I need left and right side door window strips , i am in New Zealand if that helps . Mitsubishi says they can get them but its lots of money
