I’ve removed my rear axle to refurbish while replacing brake pipes and have found 1 pas pipe that is crusty. As the other pipes are in good condition and this is car is staying with me forever i would really like to replace the crusty one with a good factory one if anyone has one they would part with ![]()
Did you find what you wanted?
Remove, sand ,clean, rust treatment paint then slot a shrink tube all the way heat shrink install done.
I think they are discontinued new so refurb is the way forward
I didn’t, no. I’ve gone down the route of refurbishment
I’ve gone down This route but what i did was cut the original hard sleeving back a little at at a time. I only needes to go back about 15mm and the pipe was pristine. I cleaned the rest up and i need to find a simular green to paint them now
