Looking to replace the 2 rubber drain tubes in the trunk of the car. Cannot seem to find the oem ones anywhere. Should I just make my own? Would any rubber tube work?
They are standard pvc tube. Just make sure that it fits tight at the top.
Any pvc hose will work. I’d just be sure to test it with a cup of water while everything is still taken apart so you can make sure you have a good seal.
Thats actually a good idea. I would for sure have put it all back together and then tested it. Not knowing if it sealed properly lol.
