Hi folks, I have removed the rear arm from the passenger side of my GTO. The bush that holds the arm in the subframes has perished and the bolt seized solid. Can I get replacement bushes and bolts? If they are available it would be good to know the part numbers and dealers selling the parts. I’m based in the UK. If it helps I have deleted the four wheel steer. Thanks Kenny
go to megazip and put in your chassis number and all parts are shown in diagrams.
usually bit too expensive so then viamoto in uk or give part number to any of big motor factors and local Mitsubishi dealer . Compare prices.
Thanks for the reply. I have most of the eight digit numbers and have tried the main dealers. I was able to order a couple of parts but I’m struggling to get bushes and the camber bolts. I have tried Amayama but I’m not sure how the order will progress!!
Hi kenny. The lower arm bushes are on ebay, just type mb663784. About £18 each.
Cheers martin.
Many thanks, sorted for all the bushes and now ready to put it all back together
