Good morning all.
I want to take off my servo soni can clean and re spray it.
Its my first time doing this. I think the bolts are behind the dasboard. Do I have to take the dash out?
Thankyou
Good morning all.
Thankyou
No, they are accessible without removing the dash.
Thanks for your reply
You have to remove the glove box out then should be accessible
Thankyou very much Jerry
Done this a couple of times now. You will need to remove the AC unit as well. The big, white thing otherwise you will never access the nuts that fasten the booster to the firewall. There are four of them.
So no need to remove the dash board. Thankyou
Nope. Remove gloveboox and the AC thing and the pin and bolts are right up to the left. You will first need to unbolt the bits and pieces on the booster under the bonnet first.
Thanks for your help
