Hello Everyone
In search of a new evaporator for a 97 GTO MR. I know the US versions are not compatible. Having difficulty finding a replacement. Any suggestions on where I can get a replacement?
Hello Everyone
Have you tried Amayama ?
No I haven’t, but it is worth a try. They always respond with an out of stock or discontinued response.
You might be best removing the evaporator core and taking it to a radiator specialist to see if they can repair it. What you usually find is a bit of the green flouro dye pooled in the plastic casing inside due to the evaporator pipework corroding where the bracket holds it.
Andy
HI
Will the Dodge Stealth ones fit
have a look here DODGE STEALTH R/T Turbo A/C Evaporator Assembly With Housing LHD MB947461 1994 | eBay
I have parts from here before and there ok
cheers
Joe
Definitely worth taking a look into. Thanks ![]()
Only a RHD unit will fit, the internal pipework is different.
