Need help identifying some wires behind the radio
Hey!
So I am trying to restore my 1991 vr4. It didn’t come with a radio. Where the radio goes there are 5 plugs. I know two go to the radio, but I’m not sure what the other white plug, the black plug and the blue plug are for. I will attach some pictures for reference.
Here is the black with yellow wire on my 93 mk1 car !
Thanks! Anyone know where the rest of the wires go?
I think the blue one is for the beeper that lets you know when the door is open with key in ignition.
@Firebirdvr4
Black plug with yellow wire is steering wheel controls
The blue plug connects to the other blue plug hanging just above that. It’s the annoying beep when the door is open
The 3 white are radio plugs. The one in your hand comes from the silver box in the blue plug picture. That is actually a factory amp. There should be a 6 pin din cable in there somewhere. That also plugs into the factory radio and comes from the amp. It loops itself. Let me know if you have any other question
Wow! Thank you so much for the help! Yall are the best :slight_smile:
Hi, I wonder if you could help.
I’m trying to find out also what colours and what their tasks are.
In particular if trying get the antenna to operate. I have an aftermarket stereo previously fitted with an antenna attached to the windscreen. I believe the plug you show with a pink wire might be the power to the antenna?
Thank you Tezza
Just go to the manuals section on this forum for full wiring diagrams.
Hi Joe,
If you mean the ones loaded by Titch 2000, then they are unavailable my end due to a bad gateway error.
I’m sure I saw a photo of the plugs in the centre consul all marked, identifying the tasks and relevant colours. I thought it was posted by one of the members but cat seem to find it. Perhaps I saw it elsewhere.
Thanks Jo.
Terry
Same issue here. All the links to the manuals return a Bad Gateway error.
I will have tech look into it.
The gateway problems have now been sorted.
