I am having some trouble with clutch and Im going to replace it as soon I found correct set. My car is Mitsubishi 1995 non-turbo DOHC model. Clutch disc dia. is 225mm, and it has 22 grooves. Anyone knows if Exedy 05048 or Exedy MBK2053 is suitable? Or if someone has a spare clutch kit in Europe, I would be interested. Many thanks in advance.
I would strongly recommend that you check with your supplier that you have the right one. If they give you the wrong one, you can send it back. If you buy one based on someone else’s advice, you are stuck with it.
