MB631514 or MB633512
Hi,
Any idea why a rear hub assembly has two part numbers? When google MB631514 I found also front a wheel hub for some other Mitsubishi model. Thanks.
I know the turbo and non turbo rear stub axles are not the same, the turbo versions have larger mating flanges/pcd for the rear axles and a larger nut.
MB633512 is the new part number for MB631514. If you were to go into Mitsubishi to order MB631514, the part you get will likely have MB633512 on it because they changed the number in thier database for one reason or another.
Thanks! It looks that original parts are no longer available, but I found a pair made by KOYO.
