Hi folks.
Quick question. I have a blank replacement key so in order to make a copy of the original one do I have to go to a mitsu dealer or a local key cutting outlet generally should be able to handle this job? Thanks
Local key cutting will do the job !
I copied mine at my local cutter and they work fine, so no need to go the usually overpriced route at the dealers
Cheers guys! Appreciate
Getting the key cut at a dealer is probably better. They will cut it to the original pattern based on VIN rather than copy from an existing key that may be worn. My local dealer required a VIN and proof of ownership to cut a new key for me.
If you have a original Mitsubishi key it will have the key number stamped on the key blade, there are many on line key suppliers that will supply a Key cut to a factory number I used Key Trader
I have attached a link : http://www.keytrader.co.uk/Vehicle-Keys/Car-Keys/MITSUBISHI.html
Hope this helps if you are not already sorted
Best Regards
Marc
