Hello all my name is:Del from Yersside,
I have a: gto 1990 t/t does thi
It would have just the single sensor on top, unless someone swapped a later engine in and modified the harness to accept the two separate sensors, or even installed a later harness.
The sensor is located on the rear head near the throttle body.
As for your crank no start you need to figure out what is missing.
air, fuel, spark, timing
All four of those are needed for an engine to run right. Figure out which one is missing, or incorrect, and then you can start proper diagnosis. Otherwise, you are just going to shotgun parts at an unknown issue, and potentially cause further issues.
