Help lost overdrive on 1992 4ws4wd GTO auto
Hi all
Was coming back from Wales and had to turn sharply doing about 40 halfway round roundabout and when I came out the other side the engine lost power. stopped and started and ok (still with OD button engaged) and it slowly lost power as put foot down on accelerator. Dont know why I tried with OD off but I could then drive the final 35 miles home in drive (went around 55MPH).
I imagine OD has a drive cog but if this went the gearbox would be gone? I know originally 7 years ago my guy replaced the"TCU" at back of dash when I lost everything , could this be reason again ?
If so anyone got one for last of MK1 as above or maybe knows what is happening, cant lose this one!!!
Hi there. The issue with the overdrive is that the end clutch has gone and will need to be replaced. There’s a cover on the drivers side of the gearbox with a external clutch pack. This happened on my gto many years ago. The first 3 gears should operate as normal but will slip when overdrive is engaged.
Thanks Ironman did that and sadly it was the other end as well and lasted half a day. Have ended up putting used replacement box on by Wayne at Japattack. Mot next Monday and should be ok except the horn wire has fallen off again and front tyres a bit close.
