Hello all my name is Alex
i’m After some help/advice if possible please.
Just rebuilt my ‘93 TT GTO engine, replaced all seals and gaskets using the specified torque and patterns etc. However when the car is running there is an oil leak (see photos)
It’s definitely engine oil but the back of the flywheel and inside the bell housing is completely dry so surely couldn’t be the brand new rear main seal?!
Has anyone else seen this before, it seems to be just on the oil pan but directly below the RMS.
I’ve tried to trace from above but all turbo feeds are fine.
Any help would be great, really don’t want to pull the trans if I can help it
It only leaks when the car is running and only a few drips but enough it won’t pass MOT, when the car is off and left overnight not a single drop on the floor
Thanks in advanced
Alex
