Hi Guys, Looking for some advice on this, I have to replace one of the Boots on my drive shaft, But in order to do this, I have to remove the spider assembly at the top of the shaft. I have already removed a cir clip from the base of this cap nut the arrow is pointing to, But I don’t know how this comes off. Is it screwed on or is it pressed on. I don’t want to damage it and have to replace the entire shaft. Advice would be greatly appreciated. Thanks
Once you remove the circlip, The bearing carrier should tap off.
Thanks Joe, Just seeing this now. I found your video on removing the CV joint on the other end of the shaft, So I removed that instead, and slid the boot on backwards over that end, Job done.
