Hello everyone. I can’t find a size on the Front Brake Caliper Mounting Bolts. I have a 1991 Mitsu VR4. Can anyone help me with size? Thank you in advance!
Are your original ones missing or just damaged?
Missing. Going to go to a hardware store but not sure on size and length.
Well here is a STARTING POINT from a forum thread someone had put together. So I can not personally attest to the accuracy of the information. I thought this post was also on here as well but I could not find it. Below this link I pasted the info they had for front brakes. At the beginning of their thread they give an explanation/legend of how they detailed the information. I hope this helps you get to a STARTING POINT.
https://www.3si.org/threads/nuts-bolts-reference-thread.681234/
front brake calipers: Done!!
2 bolts - g(8.8) - 19mm - 42mm long x 21mm wide - clear (wrong bolts)
4 pins - clear
3 spacers - clear
8 boot rings - clear
2 springs brackets - clear (bake)
2 wire ping holder - clear
2 bleeders - 10mm - 40mm long x 12mm wide - clear
8 bolts - flange - g9 - 14mm - 114.52mm long x 19.50 wide - clear
@Zivko36 How goes the search for the bolt?
I ended up getting one! It was an M12x1.25x40or 45. I can’t recall the exact size that worked.
