Hi all
I have a JDM 1997 GTO SR, the folding mirrors have always worked fine since I rebuilt the switch. however this morning I moved the car and opened the mirrors to back it into a space and once parked tried to old the mirrors back against the doors but nothing happened.
I got out and manually folded the mirrors back to the doors, I tried the switch again and the mirrors opened fine first touch, but still would not fold back to the doors.
I have subsequently swapped the window switch with a Known working one but the previous symptoms remain Mirrors will open using the switch but will only close if you do it manually.
As this is both mirrors I don’t think that the switch could be at fault, I am not aware of how the power is routed to the Mirrors so am struggling to test, if anyone has had a similar problem or has any ideas I would be grateful
Thanks in advance
