Electrical issue
Hi!
My name is Jami. I have some wiper issues with my -95 base model, front/rear wipers and washer pumps does not work. Things I have all ready tried/replaced.
  • front windshield wiper motor
  • column switch
  • etacs unit
  • fuse
  • unplugged rear wiper switch
    I notice that when grounding the fuse with a tester pen, then atleast a front wiper starts to operate. Anyone have a good quality electric drawing for a wiper circuit, maybe with a cable colours too. I guess its somekind of grounding problem. Any idea? Thanks!
Front wiper motor grounding looks to be ok. I think there is another grounding spot (nr.5) inside the dashboard with not very easy access. What is the colour of the cable that goes from column switch to grounding spot inside the dashboard?
Problem solved. It was only a loosen fuse base.
