Hello all,
I have watched many of the youtube videos but now i need more assistance than is on any videos.
I have a 1991 GTO N/A Auto
maybe important for this issue, the car has a remote key fob, alarm and immobiliser all aftermarket as far as im aware they didnt come imported with any. I have a “CODEALARM” remote unlock buttons and a "TOAD fob hanging from my keys
So i have to start this off with my car has been working without problem’s for a few months. in December due to my other car having an issue this did all the holiday travel 3 x 4hr round trips and covered 800-1000 miles without skipping a beat not a single issue.
About 2 weeks ago the other car was sorted so i was using it again with the GTO sat around for a few days while we had that very cold frosty snap(-7 where i am) It was only moved on to the driveway to have a clean and then back to the road.
I went to go move it to the drive to tinker (check underside etc) few days later and this is were everything started from so…
Tried to open the car with the key fob not working i was a bit confused as i had just replaced the battery in it so i took it apart and clean the fob internals.
No luck so manually opened the door and there were no lights coming on so battery is dead bit random all of a sudden but i guess as it was cold not used.
So i got jump cables and jumped it and it sprang to life… with the addition of one snake eye (passenger) not coming on but weirder still the driver side snake eye, tail lights and fog lights refused to go out, with the stalk turned, button pressed nothing. on all the time even with no key with the constant ringing.
After i disconnected the battery got a battery charger and fully charged and put it back on the fog lights are still staying on but no ringing tail lights and snake eyes have gone off.
I think okay ill take it for a quick drive maybe it will sort itself out, handbrake/brake light ((O)) wont go out on dash and neither will abs(skidding car) or coolant carrousel. These were non issues before it died and coolant level is fine its never lost coolant, hand brake is fine.
So i go to take it out for another drive and now my heater/aircon unit isnt getting any power no screen no reaction from the buttons so i cant drive it or it will fog up and no way to defog the windscreen.
I disconnected the fog light relay left the car, next day went to unlock it and no luck so i assume battery is dead so put it on charge to which it says full… hmm.
Open the door and interior lights come om and barrel lights up but immobiliser leds are not flashing or on at all.
I put battery back charge/maintain last night car locked at the door with remote fob not working still (im sure my remote fob is tied to my immobiliser as i have to push unlocker before key will turn engine on)
My ring doorbell alerted me to a dog walker this morning and i could see a light on the car so i went to check and the passenger snake eye is staying on without any key in the car but driver side is off other lights are off.
Battery is now disconnected while i write this with the battery cables touching.
Fog light relay will be getting put back in to check.
All fuses have been checked, relays seem okay swapped around for different ones.
Does anyone have any ideas what is causing the most random, sporadic, erratic electrical gremlin i have.
Only thing i have found so far as a possibility is the ETACS unit?
Any help is greatly appreciated, As soon as the kids are at school ill be out there trying to get it working.
