Hi all, so my ECU capacitors have leaked and I believe is the cause of my warm start stalling issue. Does anyone know of good reputable ECU repair companies for this style car who will repair and test that everything is working correctly? 1991 VR4 manual.
Hi
You might want to put what country your in, as this site has people from all over the world, I fitted new caps in mine and it ran great after, mine had not leaked and still looked new, very common now as these cars get older
Ah apologies, I am in the UK. Would it just be a simple case of soldering in some new capacitors? Would any other components need checking as a result of the leaked capacitors do you know?
There is no assurance that it is only the caps. 80% require other components and often board repairs due to acid damage. You also need to be proficient in soldering and have a temperature controlled soldering iron as these are multi-layered boards that are very sensitive to heat.
Thanks Joe.
I think on that note it’s definitely a professional company approach. I have reached out to a few places, just waiting for their responses.
I can do it for you but I am very busy at the moment so I can’t offer same day service right now.
I’ll send you a private message to discuss Joe ![]()
