yea, im going to try and go back to basics. I have already ran every scenario in my head and it just doesnt make sense.
Fuel pump is good, as its brand new, i installed it two days ago.
ECUs i think are ok, as it didnt make any difference between the two. One was refurbished by the ECU doctor in kent, and the other one, I replaced the caps myself (Id say my electronics skills are above average) but unless i can find a brand new ECU, i wont be able to tell.
IAC, gave correct readings on the multimeter, how ever that doesnt mean its operating correctly, so perhaps I could change that and they are not that expensive.
I dont think its the PTU, as once the car is running, its running fine, there is no misfire and it looks like all cylinders are firing. but yes there could be a possiblity that it is the PTU.
Now the Vapor lock issue is another thing that i havent looked into properly, im planning to come up with a method of insulating the fuel lines in the engine bay to see if it make a difference as that seems like a common fault. I was also thinking of trying a tank of super high octane fuel, as your general 95 unleaded fuel contains 5% ethanol, which evaporates much easier. Essoās super range and Shells V power contain no ethanol. Perhaps that would make a difference.
You are right about heat and electronics as heat increases resistance. High heat areas are in the engine bay, and i really cant think of anything that sensitive in the engine bay that could get effected by it
If its not Vapor lock, im down to changing the IAC, Fuel regulator, PTU and getting the injectors refurbished.
