Must be MOT time as Blue 1993 facelift TT,4WS4WD , 6 speed has the wiggly car light on permanently when moving . Turns off with other lights on ignition but flickers and stays on when you move off.
Apparently Electronic stability /traction stability ? Is there a sensor on the way out?
I dont have access to a plug in and nor do the two local guys I use.
Can I buy/borrow or hire one or even happy to drive around to find out what actual problem is .
Or has anyone solved the problem and how did they do it?
The red auto is still stuck in garage unable to properly mesh starter and torque converter so I am seriously thinking of the merits of a buss pass.
