Can anyone recommend where to get Crankshaft and Conrod bearings please? EBay has some from Poland?
Preferably not from USA as time and taxes prohibit this source.
A few years ago I got a new crankshaft from Mitsubishi UK. Bearings if you use a new crankshaft the standard Mitsubishi ones should be fine - again I would ask Mitsubishi uk.
Hi, I bought mine (crank/con bearings and piston rings) from Poland, X-tune Europe if I remember correct. Engine is still in parts, so I cant say more. Quality looks good and everything went well.
Thanks, ordered from Xtune.eu.
Hello please note that where oil pan mates to block . There will bre stamped #'s for over or under sized con bearings and mains. Mine two-years ago had under sized con bearings mains were std. Note this was with cast crank I had block milled and bored I had block line bored to match std bearings of the forged 2nd Gen crank . Just make sure new bearings are checked for minimal and maximum clearances if you don’t have access to a bore caliper you use plastigage.
