Hello all my name is Lee.
I have a GTO SR 1998.
I am going to change the coolant for the first time (myself) on the GTO. Do I have to take off the front underbody trays to access the drain plug on the radiator for it to drain out the fluid? my bolts are all rounded so will be a bit of a job to get them off! thanks
Hi, you should be able to access the plug easy, if memory serves I think there is a small plastic flap that covers it and it just needs unclipped.
