Woop woop its working now ![]()
Jey, and now you should be able to PM joe also so he will see it once he comes back from Ukraine ![]()
I know this thread is kinda old. @Joe90, wondering if you still do the CC screen fixes? IDK why I’m not able to message you. Maybe cause I haven’t had the profile for more than a few minutes. Please message me, if you can. Thanks!
Yes, I still do them.
Hi Joe
Are you still fixing these as I have a dead screen
Regards
Barry
Hi Barry
Yes I am. Please contact me by direct message rather than open forum and I can sort you out.
Hi Joe
I’d replaced the two main caps (didn’t fix it) and then noticed that R38 and a couple of the diodes looked a little burnt too.
Just ordered the parts yesterday and then found this forum and your post.
I should have the parts within a day or so, so I’ll fit them first just in case that’s all that’s needed.
Otherwise I’m going to need help and will be in touch.
It’s nice to find a forum with people to talk to, I’ve been trying to get my GT back on the road for over a year now after 9 years laid up in the garage.
The ECU had failed and three different companies here in the UK failed to fix it,
I finally found a place in Texas that fixed it, so the air con display is now the final bit to sort out.
Barry
Hi Barry
I am really sorry mate but I don’t usually repair units that have been previously repaired.
I have been spending too many hours checking for faults that have been caused by previous repairs and time is the one thing that I don’t have.
If I do agree to look at it, I will charge extra and may still refuse the job.
There’s usually corroded tracks under the capacitors, they need cleaning and repairing.
Hi Joe! Are you still active here? I’m looking to get mine rebuilt. How much do you charge? Im in Florida USA
I am still active but I will reply by private message as it is not part of the discussion.
Just noticed an issue with my ac unit. I turn it off from the display and shut off the cars power by removing the key. When the car power is turned on without the engine running, the ac starts blowing air and have to turn it off again. Any help whould be appreciated!
It usually does this when the battery has been disconnected and then reconnected. Have you had some sort of immobiliser fitted that is shutting of the power to the heater system?
This 1994 Vr4 us spec Ultimate edition is the 3rd one and l bought from Spain this April so will have to go through the wiring.
Thank you Joe
George
Hello, Im new to this forum.
I drive an '93 Doge Stealth. And this morning the display of the climate control
gets dark. I life in Germany and would like to now, if its possible to get it somehow repaired.
I have changed it about 8 years ago and I have the original part still in stock. So I could send also this for repair, if possible.
I can repair these for you but I am tied up until early next month. Please contact me by private message if you would like to send them to me for repair. My son is in Germany at the moment and may be able to bring them back to me for you.
Hi Joe,
Thank you for the fast reply. I can also send it. How much are roughly the costs for the repair? I have enough time. Im also anyway in holiday from mid sep to mid oct. But I can send the part to you before.
Are you in the UK?
Best regards, Roger
I am in the UK. It is £55 per unit on the condition that no repairs have already been attempted. My son is in Germany until tomorrow.
Hi,
Thank you. Im in Heidelberg. Not sure, if its not too far for your sun to come extra. I can also send it. The part is from original car. But Im second owner. But I didn’t let it repair.
Repairprice is fully ok.
Best wishes, Roger
Hello joe,
If you can send me your address, i can send the part next days. Do i need to declare it as used carpart or so? For the custom?
