Check engine light
Hello all my name is: Jim
I have a 91 VR4 with only 64,000 miles.
It has the following issue: Driving the car if you have the motor reach high rpm 5- 6000 in 4th or 5th gear the check engine light will come on, car runs fine. Turn the car off light goes out and doesnt return until you drive it at those rpms again. I used a scan tool but it is no use due to light going away when you shut the car off. Any ideas??
Hello, I am not an expert, but Perplexity gave the following answer when I put in your issue:
The issue you’re describing on your 1991 VR4—where the check engine light (CEL) comes on only at high RPMs (5,000–6,000), but turns off when you restart the car and leaves no stored code—suggests a few possibilities common with older Mitsubishi VR4s and related models:
Common Causes to Consider
  • Transient Sensor Signals: At high RPMs, sensors like the crank angle sensor, cam angle sensor, or mass airflow sensor may give intermittent faulty readings due to vibration, aging, or wiring issues. These can trigger a CEL only at high engine speeds but not persist or store codes if the engine is shut off and restarted[1].
  • Ignition System Issues: Problems with coil packs, distributor (if equipped), or ignition wiring can manifest only under higher loads/RPM when voltage demands are highest. This often doesn’t cause drivability symptoms but can still trip the CEL[1].
  • O2 Sensor Anomalies: While less common, a failing oxygen sensor could sometimes trigger a light at specific operating conditions at high RPMs, especially if the ECU temporarily goes open-loop at higher revs, masking an error at lower speeds[1].
  • Knock Sensor or Fuel Injector Sensor: Faulty knock sensors or injector circuits can trigger warning lights under higher engine load or RPM, even if no clear faulty behavior is sensed during normal driving or idling[2].
Troubleshooting Steps
  1. Manual Code Retrieval:
    • For OBD-I Mitsubishis (like your '91 VR4), you can usually read stored CEL codes by using the diagnostic port and a jumper wire (or counting the flashes of the CEL). Even if the light turns off with a restart, try the manual method immediately after the event, without cycling the key completely, if possible[3].
    • If codes are not stored, it’s still worth trying, as some ECUs retain a code until power is completely cut.
  2. Check Sensor Connections:
    • Inspect and clean all primary sensor connectors, especially crankshaft/camshaft sensors and the airflow sensor.
    • Carefully check the wiring loom for signs of chafing, loose connectors, or corrosion, especially in areas subject to movement or strain at high RPM[1].
  3. Ignition System Tests:
    • Visually inspect spark plugs, plug wires (if present), coil packs, and all ignition system connectors. Small cracks or excessive resistance can cause issues only under high load.
    • Consider checking or replacing the ignition module or coil packs if they are original.
  4. Knock Sensor/Injector Circuits:
    • If possible, check the knock sensor (usually screwed into the engine block) for cracks or loose wiring.
    • Fuel injector connectors and wiring should be tight and clean.
  5. ECU Capacitor Check:
    • 1990s Mitsubishis are infamous for failing electrolytic capacitors inside the ECU, which may cause random CELs at higher engine stress, even without noticeable drive symptoms.
Notable Observations
  • The fact that the car “runs fine” even when the CEL is on suggests it’s likely not a catastrophic sensor or fueling issue, but more likely a signal irregularity that only surfaces under the unique conditions of high speed and load.
  • If you can replicate the problem while stationary (revving the engine in neutral to 5,000–6,000 RPM), see if the CEL comes on. This can help rule out load-related (vs. RPM-only) triggers[1].
Next Steps
  • Use the manual code reading method on your specific ECU, and try to do it before cycling the ignition off.
  • Visually and manually inspect primary sensors and ignition components for signs of age or wear.
  • If issues persist and you are unable to get a stored code, it may be worth consulting a classic Mitsubishi specialist, as high-RPM CELs on these models are often related to aging wiring, sensors, or the ECU itself[1][2][3].
If you have any more specifics (like driveability symptoms, recent repairs, or modifications), or if you can capture any codes, I can help narrow it down further.
Citations:
[1] Check Engine Light, goes off @ 4000 ish rpms - https://club4ag.com/forums/viewtopic.php?t=7997
[2] Check Engine Light On and Off - GalantVR4.org https://www.galantvr4.org/threads/check-engine-light-on-and-off.21992/
[3] Worst 3000GT VR4 Check Engine Light (How To Read Codes) https://www.youtube.com/watch?v=bCpTQvOh-vg
[4] 91 gto vr4 sputtering bad at higher rpms : r/3000gt - Reddit Reddit - The heart of the internet
[5] Engine Knocking Loudly!! - Club VR-4 Forums https://www.clubvr4.com/forum/showthread.php?p=731874
[6] Mitsubishi Sirius engine - Wikipedia Mitsubishi Sirius engine - Wikipedia
[7] Check engine light goes away at 4k rpms comes back then struggles … Reddit - The heart of the internet
[8] check engine light tripping and rough at low RPMs? https://www.nsxprime.com/threads/na1-nsx-check-engine-light-tripping-and-rough-at-low-rpms.219728/
[9] Engine Stuttering Under Load | OZVR4 https://www.ozvr4.com/threads/engine-stuttering-under-load.9287/
[10] Check engine light on and RPMs keep jumping https://www.dsmtuners.com/threads/check-engine-light-on-and-rpms-keep-jumping.441338/
[11] check engine light comes on after fitting bigger intercooler - Club VR4 check engine light comes on after fitting bigger intercooler
Hope this helps you finding the problem. I would go from checking the easily accessible parts to the harder ones. Good Luck :four_leaf_clover:
Thank you! I will start investigating.
