Cam/crank shaft position sensors
Recently got a check engine light and it says i need to replace both the crank and camshaft position sensors, i’d like to do it myself to not pay the mechanic but i can’t find any information on where they are, does anyone know…?
The location depends on the year/model of engine that you have.
You will find all the information as well as set up instructions in the manual.
i have a ‘97 SHOC engine, and i don’t have the owner’s manual and cant find any online
You could try NinjaPerformance.com. Click on the left side menu button. Then click on guides. I hope this information helps.
You will find all of the manuals in the category called manuals and documents.
