Hey guys.
I have a dilemma. Finally got to the air conditioning stuff, and currently not too sure what path to take with the condensor.
The system works fine, blowing arctic cold, no issues at all, however upon closer inspection of the condensor, as I keep dighing into the front end, it seem to have seen better days. It is badly corroded. No leaks tho, nothing.
I have a replacement one in a nice shape but so I am a two roads - either cleant up it as much as I can (will lose quite a few fins as it literally crumbles upon touch) or replace but given it is R12 I’ll then need to go down the road of conversion to R134 which might be a pain from what I gathered…
Hence need your opinions - what would you do and if you did a conversion - what is the most painless way? (There are tons of different opinion on that on the Internet)
Much appreciated
