Hello all my name is: Anton
I have a: 1991 twin turbo gto
It has the following issue: the active aero rear spoiler wasnt working, i removed it and checked for faults motor is ok micro switches need to be replaced but the bigger problem i have is the cable is broken from the both sides where it stuck inside the white plastic to move the wing. Can the cable be repaired or replaced i didnt find any replacement for the cable.
