Hi everyone,
I`m after the rear - Mitsubishi 3000gt MB852400 Active Aero Control Module - anyone got one for sale?
Thank-you
im sure i have one.will look tonight
rik
Morning Rik,
any luck finding the control module?
Thanks.
still looking…is this module located in boot?
rik
Hi Rik,
yes it`s in the boot, passenger side, to the rear of the radio ariel,
has a blue sticker on it with MB852400 - TYPE G8C-88M - No ______ OMRON MADE IN JAPAN,
hoe that helps.
What symptoms are you having to think the active aero module isn’t working ?
I’m looking for possibilities as my active aero isn’t working either.
I’ve got power at the fuse and the switch but not at the front motor, not sure sure if power should be there when you switch ignition on or do you have to press the active aero switch to get power there ?
Cheers Mark
Hi, Mark,
Our problem was the rear areo module, second hand one got now all`s fine.
Would you happen to know if you’ve got 12v power at the front motor with just the ignition switched on or do you have to press the active aero switch to get power to the motor ?
Thanks Mark
Hi Mark,
