Hello everyone, after some research I’ve found out that my 93’ 3000GT SL (NA) won’t start because the ECU broke, it was one of a Dodge Stealth.
A mechanic told me he could buy an empty one and program it for 3500€ but that’s too much for me.
Let me know if you can help me to get one!
Best regards, Raphaël.
hi
Just buy a used one with same part number on it and it will work, also its only the capacitors that fail in the ecu and they can be fixed as long as they have not leaked too much and damaged the pcb
Hi sorry to here about your ECU , have you opened it up and had a look at it ?
Mine did the same the very capacitors leak over time and errode the tracks on the board .
all you might need to do is replace capacitors and repair tracks on board , job done.
or
or
some one there can fix these no problem for a lot less than $3500
Happy shopping
Thanks a lot for your answers!
I contacted SIA Electronics and I’m looking forward an answer.
I hope this will turns out good ![]()
I was wondering, can the ECU of a bi-turbo be used for a NA ?
