Evening all,
Could some one please let me know how to remove the metal electric sun roof. Mine has a few rust spots that I would like to treat.
Evening all,
Open the sunroof - use a long trim tool or something similar to pop off the inside sunroof liner. Then with this off there are 4x 10mm nuts to undo and the sunroof lifts off. The best way to treat them is to remove the seal carefully and then take the panel back to bare metal inside and out and then have it re-sprayed. The problem with these panels is once water gets into the seam it needs to be completely removed and treated.
Great thank you James
