I am curious on how often your cooling fans activate when you are stationary with your car and the engine is running and it has hit normal operating temperature…
Mine turn on every 10´ish seconds and run for a little while and then turn off again, and I was wondering if that is the normal procedure for them???
The engine temperature never fluctates one tiny bit, so it is not that the car is overheating… I am just curious if your activate as often??
Hmmm, I better check in there which of the fans is running… I just noticed it this evening that it sounded louder then normal every 10-15 seconds just for a few seconds… But it is only after the car has hit operating temperature
I was just outside and checked… The small fan only activates when I turn on the AC, otherwise it sits idle, and the large fan activates when the car has hit operating temperature, but it still activates every 10-15 seconds when the car is stationary, and runs for a few seconds and goes back to idle… I wonder if it is suppose to be like that.
Ok, then I will not worry about that … Just thought it activated very often for short bursts when stationary, but if others are doing the same, then it most likely is all allright unless everybody else´ is also broken
The description of the main fan cutting in and out every 10-15 seconds is how it’s supposed to run.
The air cond fan is constantly running, if the air cond is on.
It only runs otherwise if the main fan can’t keep the temp controlled.
Marty
