Hi Guys
Currently my rear hatch is higher on one side, is there a way a level this? Though it mite make a good video
Any tips are welcome thanks in advance !
Hi Guys
Levelling and alignment of doors is a bit of an art. The best body shops will have a specialist for the job. I can’t tell you a quick fix for this myself but I would consider doing a video if no one else comes forward with a secret to the perfect fix easily.
Depends if it’s not level at the hinge or at the rear edge. There should be rubber height adjusters at the back which you screw up and down. Ideally the hatch should come into contact with these rubber adjusters at the same time and then a slight pressing down at the rear lock/catch should hold in place. If the hatch is high on the left side try lowering the rubber stopper on that side too.
I believe the hinges at the top are good, I just adjusted the rubber stoppers and it made a huge difference but it’s still alittle high I’ll mess around with it abit more. Thank you really appreciate it !
