Fuel Sender Hose
I have been asked to list some replacement fuel sender /pump connection hoses. Apparently, some of you are having trouble getting these made. The hose goes between the sender unit in the fuel tank and the fuel line that runs under the car to the fuel filter.
These have been made with swivel nuts at each end so fitting is much easier. It also has E100 compatible hose so there is no compatibility issues in the future with fuel types.
NOTE.! You MUST use a tiny spot of thread lock on each end to prevent parts working loose due to vibration and movement. (as per manual)
I’m afraid the price is £30 each plus post because I have the parts assembled by a professional hydraulics company to be sure that they meet the correct specifications.
Just send me a pm if you are interested.
