Hello again My Friend,
This is the first time I‘m trying the forum instead of YouTube, Hope this works!
I just bought my 1999 SL and filled up the gas for the first time. I’ve been driving it a little and my Optima a little too because I need to change the timing belt, water pump, camshaft sensor and flush the coolant. Point is, I filled them both up at the same time and I noticed my optima was down a quarter of a tank and my 3000GT was still full. Initially I thought, wow, this car has great gas mileage! But then I thought, it’s a V6 3L and the Optima is V4 2.4L, that doesn’t make sense. When I turned the Car off, I noticed the gauge did not fall down like it’s supposed to. I was driving it so obviously the fuel pump works, so I think the sender or wiring may be bad. I’m not sure if there is a fuse or if something else like the actual gauge is stuck. I checked the price for a sender, unfortunately for all of us 3000GT owners, the sender and pump go together and costs like $700 bucks! Good lord! Would you do a video on this issue? I’ve watched a few other channels on this topic already but I like yours the best so I’ll wait for a video before I attempt to fix anything. hopefully it’s a simple issue and not the $700 issue.
Thanks in advance,
Gold Wolf, USA
