Hi all, especially the clever ones… wanting to change my BC Coil-overs for standard ECS ones. Is it possible to lay the complete struts on each corner of the car and connect the Wiring Plugs to them to check if they are OK? Doing this, would the Switch show a Fault?
Still loving the car!
I would like to follow and wonder if there is a way to test the struts off the car (or a way to diagnose if its wiring or the strut itself or even a fault ECS computer)
I’m sure on one of my previous cars I laid the shock on the car and connected it. I checked the Caps with a meter to check continuity, but it was a long time ago!
You don’t have to install them on the car, just connect the plug to the top of each shock.
