I know that it is similar to every other ebrake shoe replacement. However I have heard that there is difficulty because of the hub. Is there an easy way that does not require removing the hub? Can you show me?
There is no need to remove the hub. Brake shoe replacement is the same as most other cars. Just pull off the brake disk/drum and you will see the shoes. I will add this video to the list anyway.
